table entry
Hi all,
I have implemented a code which enters values in the table at a event (when transition occurs from off to on).
I have attached my code below,
Can anyone suggest a better way to do this, or some comment on the code to optimise it.
regards
Message Edited by Cool : ASDF on 02-19-2010 03:09 AM
Message 1 of 8
(4,122 Views)
where is the code?????
Regards
Guru (CLA)
Message 2 of 8
(4,117 Views)
sorryi forgot to attached
Message 3 of 8
(4,114 Views)
here you go..
now find the difference 🙂
Regards
Guru (CLA)
Message 4 of 8
(4,106 Views)
Hi
I dont want to change the mechanical action of the button
regards
Message 5 of 8
(4,090 Views)
Can you explain your response? You explicitly asked if there was a better way or comments on optimization and then you reject them. Your mechanical action is incorrect for your usage and if you were to change it, you would not need the case statement. At the same time your are ignoring the advice, why don't you change the mechanical action of the stop button as well? That would make as much sense.
Message 6 of 8
(4,067 Views)
Sorry for that but actually i want that mechanical action in my code.
I want that button on till user want and when he switches that button off, the value at that point should be entered
in the table.
Regards
Message Edited by Cool : ASDF on 02-19-2010 11:27 AM
Message 7 of 8
(4,058 Views)
Okay, that's your decision but that is counter to what most users expect. Click once on the button and the operation happens. And, the button is 'Off' until clicked and when the button is 'On', the value is entered. which by the way, is exactly what happens when you use the correct mechanical action.
Message 8 of 8
(4,054 Views)
