delta Design drivers
Hi
Anybody has Delta Design 's drivers. I am looking for 9028  or 9010 Temperature Controller (delta design oven).
(4,262 Views)
I did a search on our instrument driver network at ni.com/idnet, and I did not find any drivers for the controllers you mentioned. Have you tried to contact the manufacturer to see if they have any drivers for you? You could try using the Instrument I/O assistant to help get you started. Besides that, I am sorry there's not much help I can offer. Goodluck!
Message Edited by _Belle on 06-05-2006 03:24 PM
Ebele O.
(4,250 Views)
The original post her is from 2006 but I see multiple views so others are looking for the same driver(s).
"Does anybody have Delta Design 's drivers? I am looking for 9010 Temperature Controller (delta design oven).
Any help is appreciated,
(3,983 Views)
The 9010 controller likely what you want to interface with (it controls the Delta Design oven temperature).  You can get a set of command codes to talk to the 9010 controller from Delta Design directly (it's in a pdf from the 1980's).  The 9010 controller does not have prebuilt LabView drivers and the company has no plans to make any due to the age of the device.
The controller command codes look like a variant of BASIC, so I'm here looking for a way to turn the command text into commands that I send to the device and execute.  I hope this helps people!  If I have to do anything weird to get the command codes to run from LabView, I'll let you know.
(3,835 Views)
