table content
Hi : attach see file please , I have table which contain some data … I wnt to know every parametrs where is index in table ( row and column )  for example : I have number 365 and text Volt … I want to know where its index  Number 365 row 0 column 1Volt existing at row 0 column 3 How can I do that in Labview  Thanks
(3,701 Views)
Hi wisam,
you could index the colum to search and then use "search in 1D array" to look for your string.
Or if you need the other way around you simply use "index array"...
(3,699 Views)
Hi : can you help with this? by sending the solution in vi thanks
(3,695 Views)
Hi wisam,
oh, come on!
Its just some functions from the array palette, so please explore them with the help of context help/detailed help and examples provided by LabView Smiley Wink
(3,691 Views)
Accepted by wisam elyan
GerdW wrote:
oh, come on!
Agreed. You need to plug away at these things yourself, or you'll never learn. People here are more than glad to help, but writing VI's for you isn't the idea.
Richard
(3,682 Views)
