tab control
@RavensFan wrote:
In the image you posted it says "Tip:  You can wire the enumerated control to a case structure.... "   It doesn't say "you should" or "you must".
also it didnt say you shouln't do. So what you said in the begining is not fair.
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
Message 11 of 13
(1,326 Views)
Yes it was fair.  RavensFan was warning about architectural issues involving the tab container.  I could also use a global variable and have two loops write to it.  That does not mean I should because it will cause problems (specifically race condition).  Similar situation with the tab control.  That architecture will lead to problems.
Message 12 of 13
(1,308 Views)
"can" is not equal to "should"
You "can" go jump off a bridge.  But I would never tell you that you "should" jump off a bridge.
Message 13 of 13
(1,290 Views)
