tab control
In my tab there are 4 pages.I closed  'show page select' because  I want to use 'ok' button to select page.I uesd the Event Structure to realize it.but I failed .is there anybody  can  help me or shou me examples?
thank you!
fay
(3,585 Views)
Hi fay
There exists a vi-template for wizards, which uses the tab-control. I attach it for you and hope it helps you to solve the problem.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,581 Views)
hi,becktho
I got it. And I appreciate your time and help.
Thank you again for so quick!
(3,574 Views)
hi,becktho
I need to add some code whicht is ued to calculate numerics many times,so it needs another while loop to that dialog vi.but when I this while loop,the first loop can not stop ,how can i do??
thank you advance.
fay
(3,559 Views)
hi,becktho
I need to add some code which  is ued to calculate numerics many times,so it needs another while loop to that dialog vi.but when I  add a while loop,the first loop can not stop ,how can i do??
thank you advance.
fay
(3,558 Views)
Hi fay
Have you already found a solution? If not - could you describe a little bit more what you want to do? If possible - could you also post some code or a picture (no *.bmp please)?
Using LV8.0
(3,510 Views)
