tab control using keyboard functions
Thanks very much for helping with my questions.
I want to know how to open different tabs of my application using key board keys (hot key).
(3,373 Views)
Hi suni,
if you mean, how to select different pages from a tab control, then you can use an event structure. Create a key down event and check the pressed key. If it was a defined key, then change the value of your tab control.
Hope it helps.
Mike
(3,371 Views)
One way would be to use an Event structure to capture keystrokes, and write a constant to the tab control terminal (or local variable of it).
(3,370 Views)
Accepted by topic author suni
Once the tab has key-focus (either tab to it or set key-focus) the left and right arrow keys will select different tabs.
Ben
(3,364 Views)
