tab control scroll
Hi All
The attached vi allows me to scroll sequentially through a number of pages using the mouse down anywhere on the pane.
When the scrolling reaches the last page, I would like the process to start from the first page again. In other words continue the cycle...1,2,3,4,5,1,2,3,4,5,1,2,3,4,5 etc.
But....I'm stuck at how to achieve this.
Could somebody, please, give me some assistance as to how I might do this?
Thanks for any help
Ray
(3,827 Views)
I think this will fullfill your need....
Dont forget to give kudos for good solution....
Smiley Wink
(3,819 Views)
Accepted by rayclout
One option is to use a shift register in the while loop.
In the attached I use a property node to calculate the number of pages on the tab. Using a combination of shift registers and quotient/remainder you can cycle round the page numbers. You now only need to write to a property node instead of reading then writing.
Note that your stop button is not working as you might intend. This is due to your 5 second timeout in the event structure. You may want to look at alternative ways to implement this.
(3,817 Views)
Br.anad and _Ian_
Both elegant solutions, and much less coding work than the example I posted.
I wired them both up and learnt what was happening, but I think I preferred _Ian_' solution.
So, I will give the solution to _Ian_, but I will try to give kudos to both.
Thanks guys....I really appreciate your help. I'm still on a learning curve.
Best regards
Ray
(3,790 Views)
