systemexec.vi input
Dears,
C:\Documents and Settings\admin\Desktop\devcon\i386
Inside this folder devcon.exe was there.
if we give the command devcon find usb*  it will show all the usb devices attached in the system.
please give a screenshot of how to run this in systemexec.vi
Thanks & Regards,
Mathan
Message Edited by mathan on 05-28-2008 02:11 AM
Message 1 of 11
(7,221 Views)
Accepted by topic author Mathan
Hi mathan,
this works. Smiley Happy
Mike
Message Edited by MikeS81 on 05-28-2008 09:28 AM
Message 2 of 11
(7,215 Views)
Nope mike,
it results in error 267.
[Edit: Hey now its working without any problem.]
Message Edited by mathan on 05-28-2008 03:24 AM
Message 3 of 11
(7,205 Views)
You will get error 267 if the "working directory" input to the System Exec VI is not a valid path to an existing directory. Please double-check your path entry, and also make sure there are no non-printable characters, like extra spaces or carriage returns in the path.
RayR
Message 4 of 11
(7,174 Views)
RayR
Dear JLV,
Yes your suggestions are correct. The path entry i chosen was wrong and mike's example corrects it.
Mathan
Message 5 of 11
(7,165 Views)
Glad it works out for you 🙂
It's often the simple errors that we miss..  😉
Message Edited by JoeLabView on 05-28-2008 08:38 AM
Message 6 of 11
(7,160 Views)
" ... and also make sure there are no non-printable characters, like extra spaces or carriage returns in the path."
And my rookies look at me crazy when I harp on not using spaces in file specs. Sometimes you just have to protect them from themselves. Smiley Very Happy
Ben
Message 7 of 11
(7,153 Views)
Those invisible spaces can be nasty..   is there 1 or 2 spaces??  LOL!
Message 8 of 11
(7,146 Views)
Trailing spaces are the worst!
A - Trailing space in this constant
B- Results in creating folder without trailing space but returns original path WITH trailing space.
C- Archiving distrubutes the files in both version of the folder.
And just for bonus points, Windows will not let you delete a folder with a folder spec. You have to use a DOS command to fix this. Smiley Mad
Ben
Message Edited by Ben on 05-28-2008 08:44 AM
Message 9 of 11
(7,136 Views)
Mike S81,
I just used your solution that you posted for devcon on this post and wanted to thank you for figuring this out.  You saved me some time.  -SS
Message 10 of 11
(6,973 Views)
