system exec, Program doesn't save its data
I have build a very simple VI which is calling an *.exe file with system exec. The program is grabbing some image data with a matrox helios card. All seems to be working correctly but the program should save the grabbed images as an *.avi file (108MB size). But this *.avi file is not saved when I use system exec.
When I double click the programm under windows all is working fine. It grabs 120 Images in 2 seconds and saves them as *.avi.
Anybody have some ideas which could be the problem?
(3,298 Views)
Hi Porrm,
can you post your vi?
Mike
(3,294 Views)
(3,290 Views)
Hi Porrm,
can you set the path, where to save the 108 MB file? Is it possible with an additional parameter? I think it could be that the path is the problem.
Mike
(3,255 Views)
Hi Mike,
you were right! When I set a path it is working.
many thanks
(3,229 Views)
