system configuration VIs missing
I had DaqMX installed on my PC and used the System configuration VIs under Measurement I/O (mostly the Find.vi) to Get the a list of the installed cards in my system.
It worked just fine, but once I remove the DaqMX and install only the Traditional Daq, the System VIs are removed from Labview and my vi is broken.
* Is it possible to install these VIs from anywhere or do they come only with DaqMX ?
(I tried to copy the whole folder of these VIs from another PC, but then I got many messages about missing DLLs
* Is there any similar VIs I can use with only the Traditional DAQ installed ?
* Any other way to get the list of installed devices from MAX or the Device Manager (preferable), which I can apply on a system with or without the DaqMX ?
I'll be grateful for some ideas...
(2,793 Views)
if you're just trying to get back the system configuration VIs, you should be able to install them here: http://joule.ni.com/nidu/cds/view/p/id/3667/lang/en
We do not recommend that you use Traditional DAQ, this is a legacy product that we no longer support.
If you use MAX you can generate a report that has all NI software installed. Could you explain what you mean by getting a list of installed devices? Are you looking for all hardware that's connected to a machine?
Gabriel M.
Product Marketing Engineer - Academic Courseware
(2,751 Views)
Spoiler
Spoiler
Thanks for the link for the Configuration VIs!
Spoiler
Regarding the HW - Yes, I need the details of all the HW connected to the machine. I think the Configuration Find.vi will do the job.
Spoiler
Spoiler
(2,726 Views)
