06-04-2010 04:04 PM
06-07-2010 03:40 PM
06-08-2010 05:50 PM
yes, I could FTP it. However, the reason I am doing it this way is that potentially I have multiple files on the PXI side that are being combined into a single file on the PC side. The PXI has a file size limitation of 1 GByte and I could easily be collecting 2-4 GBytes.
06-10-2010 10:48 AM
Hello faustina,
After reading your post, I have a few more questions to ask you about this to help you solve this issue. Which version of LabVIEW Real-Time are you using?
Also from the pictures I have seen, it looks like you are sending the entire file over in one chunk of 700MB-2GB. This isn't the recommended way to send the amount of data across TCP/IP because of the problem you are seeing. In order to fix this issue it is best to divide the file into chunks of smaller sizes to send to the host. This will decrease the amount of memory and CPU usage dedicated to this task.
The other concern I have with the TCP/IP connection is its location in your code. Is it located in the time critical loop on the target? If it is, it will need to be removed from that loop and place in a different loop by itself. The reason for this is that TCP/IP connection is nondeterministic because it has to communicate over the network and with a Windows system.
I hope this information helps you with it and if you are still running into problems with execution time, I would suggest the Real-Time execution Trace toolkit. This will allow you to monitor the execution time, CPU usage, memory, and much more of a set of code.
06-10-2010 11:38 AM
Two thoughts come to mind.
1) What is the harddrive status? A fragmented almost full dirve can slow down the file writting after it fills the big gaps and has to start writting to scattered sectors on the disk.
2) What is the hardware connection between the machines? I have read of switches that throttle I/O after you go over some limit.
That's all I have to offer.
Ben
06-10-2010 03:15 PM
I am running LabVIEW RT 9.0. The Target code is not residing in a time critical loop. Data is being transfered in chunks of 524288 bytes (see probe location 1). The hard disk on the PC was fragmented so I ran a defragmentation application to clean it up. The only hardwared connection between the PXI and the PC is a 1 GBite ethernet line.
I have since tried to copy all the files from the PXI to the PC via FTP on MAX. I was hoping to combine the appropriate files into a single file on the PC. However, when I FTP, after every file download I get the following message "connection time out. closing FTP client" My file sizes are 1073741824 and 1023410176 bytes. Is this because it is taking so long to download one file?
06-11-2010 11:34 AM
Hello Faustina,
After looking at this code a little further, I have a few more questions to ask. In the code you are reading the data from a file. How are you saving the data? Is this done in the time critical loop? If it is, then since this resource is being used by both the time critical loop as well as the lower priority loop, this will introduce jitter into your system and causing these delays.
As for losing the connection during the FTP transfer, this problem could be caused by a slowed network connection or the RT target is closing the connection to conserve its CPU usage. It is hard to dianogisis these problems because each person's network is slightly different.
06-11-2010 11:47 AM
Jim_S wrote:...
Real-Time Trace Execution Toolkit?
Ben
06-11-2010 04:06 PM
08-25-2010 07:30 PM
Changing the chunk size does not resolve the problem. I've reduced it to 4096 bytes and still can have the 'door' slammed shut. In the enclosed files I can increase my network utilization (especially if I don't write to disk) to 20-23%. Even if I include the writing to disk network utilization fluctuates rapidly from 6-18%. But I can't figure what suddenly reduces the network utilization to below %1 effectively slamming the 'door.' There are no errors for either of the TCP read/write function calls. This occurs even if I disconnect from the ethernet and connect directly to the PXI.
