subvi in subpanel
i have a programme working nicely,  but when i load it from a top level in a sub panel
FP  display but commands doens't seem to work
a way on how to obtain same behavior as direct use ?
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,867 Views)
What commands don't work?
There is a lot of missing information in your post that makes it impossible to know what you're doing to be able to help you fix it.
Perhaps you could post an example?
(3,861 Views)
Yes
here an example
(3,853 Views)
  ouch i missmatched
here is the example
(3,838 Views)
Accepted by topic author tinnitus
Hello Tinnitus,
The "Insert VI" invoke node only loads the front panel of a VI into the panel, it does not actually run the VI.  That is why the interface loaded within the subpanel is not working, you must also run that VI.  You can either run it statically by like I did in your example that I am reloading or you can call it dynamically.  Check out the examples in the Example Finder, there are 3 decent examples that show you how to all VIs dynamically.
(3,832 Views)
hello gt8860a,
I am looking for a solution to preserve both loading dynamically into a subpanel, both the strict link of a direct sub-VI call.
Maybe your code can help me but I have LV 8.5. Can you help me?
Thx
Fra7
(3,425 Views)
