subvi always open
In development mode, when I open my main vi, a subvi always open as well.  What can cause that?
Kudos and Accepted as Solution are welcome!
(2,972 Views)
Maybe your subVI is set to "show front panel when called" from its vi properties..?
(2,969 Views)
or "show front panel when loaded" from its vi properties..?
(2,966 Views)
Accepted by jyang72211
It is likely the Show Front Panel When Loaded property.  It can be found in the Window Appearance of the VI Properties (you will need to use the "customize" button in order to actually find the property).
(2,957 Views)
show front panel when loaded is it.  It was greyed out, so I wasn't aware of it.  Thanks!
(2,933 Views)
