subtract a constant(x,y) from the elements of a 2D array
Hi
Can anyone tel me how I can subtract a constant (x,y) from the elements of a 2D array?
(3,207 Views)
(x,y) is not a simple constant, but at least two constants (x, and y). What kind of 2D array do you have.
Does it have exactly two columns (or rows) and do you want to subtract e.g. x from row 1 and y from row 2, for example?
Of course if the elements of your 2D array are e.g. xy clusters, you can just subtract the single xy cluster with an atomic subtract node. Other cases might need a loop.
Your question is not clear. Please attach a small VI containing typical data. Thanks!
(3,206 Views)
The VI is attached. I do not know if it is the correct way of doing it, could you please check it?
(3,196 Views)
Your VI does not contain a 2D array.
(3,187 Views)
