subpanel errors
hello,
i've got a subpanel in my application. when i start the application i got an error called "An input parameter is invalid" or "VI Reference is invalid"
or " The VI is not in a state compatible with this operation".
i used the example viewer.vi.
some vi's which are called for the subpanel are running in the application.
can anyone help me?
markus
(2,896 Views)
Hello Markus,
please create and post a zip with some small VIs showing the issues you are mentioning.
Then I could habe a look at your code and try to figure out what is going wrong.
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(2,883 Views)
hello,
here is my vi. this is copied from my application.vi.
now i get errors caused from "insane object".
markus
(2,872 Views)
