Is there a way to simulate a menu click ?
Is it possible to simulate a click on a menu item to use dynamically this menu item "procedure" ?
Then, is there a way to interact with the menu of a subVI or a supVI ?
Many thanks in advance,
Gerry
Message Edité par Etrelec le 04-12-2005 03:23 AM
(2,429 Views)
Hi Gerry
Have a look at the attached demo. It pops menu selections into a user event which your code can then act on. Also you can set the user event with the required menu item and again your code will act upon it.
Hope this helps
Message Edited by SciWare on 04-13-2005 02:22 AM
Kurt Friday
www.sciware.com.au
(2,402 Views)
