subpages
hello,
ı want to transient from one page to another page without tab. For example when ı am on main page ı want to switch to another page by pushing any button. I am using labwiev 8 student addition. does it give any trouble ?Can you give me any recommendations? how ı  do this vi?
Message 1 of 28
(5,514 Views)
Hi ugur,
what are "pages" to you?
What are "any button"? Frontpanel objects of real hardware buttons?
When you talk about tab pages: you can set the active page by writing into a local variable of the tab control.
Message 2 of 28
(5,504 Views)
Page of what if you aren't using tabs? You can still use the tab folder control, configure it to not show the actual tabs (right click on the tab control, select "Visible Items" unselect "Tabs"), then using an event structure (see the Help:Find Examples on the vi toolbar) and use your buttons to switch between the tab pages.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 3 of 28
(5,502 Views)
You still use a tab control, but turn the tabs off (a right click function).
The tab control is an enumerated data type that you can read from and write to on your block diagram to set the tab that is viewed. You, then need to create buttons and code that reads the buttons and writes the correct value to your tab control. The tab control is an enumerated number that you can use any numeric function on like +1 or -1 to page forward or back.
Omar
Message 4 of 28
(5,499 Views)
..If u have many number of pages, then find the number of pages using Pages property and array function. Then use it to go forward and backward like +1,-1 like Omar_II mentioned
Nghtcwrlr
Message 5 of 28
(5,493 Views)
Place a classic tab-control, make tabs invisible, paint background and borders transparant. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 28
(5,486 Views)
hello guys again,
firstly thanks for everyone who contributed. ı put an example may be it specify what ı mean. as an assumption whenever ı push the temperature button temperature page will open or whenever push the oil pressure oil pressure page will open and show parameters like inlet pressure outlet pressure etc. and also there will be a button for going back home page or next /back button to go specified pages. shortly my purpose is to control so many pages and every page will have their own front panel
NOTE: I ATTACH AN EASY EXAMPLE TO EXPRESS WHAT I MEAN
see you thanks again
Message 7 of 28
(5,464 Views)
That example VI has nothing to show what you want instead of tabs. Everyone understands the concept of some front panel Booleans. Have you tried using tabs? What is you objection to all of the answers that suggest you use them?
Message 8 of 28
(5,460 Views)
i mean subpanel control
http://www.youtube.com/watch?v=1vp3xnMVv6o
after looking at video i am sure you will understand what i want to express
thanks
Message 9 of 28
(5,438 Views)
Do you mean something like this?
Nghtcwrlr
Message 10 of 28
(5,429 Views)
