subVI input
I have created a SubVI which contains only indicators and a few buttons.
I have attached each of the indicators to the connector pane, however when I insert the VI into a block diagram the connections only show as outputs.  How do I get the connections to become inputs so that I can send data to the indicators?
The VI is attached.
(5,083 Views)
Accepted by CHRISINSPEC
Hi Chris,
THINK DATAFLOW! (It's the way LabVIEW works!)
Indicators do output data, so the subVI connectors connected with them will output data too.
In contrast controls are data inputs. So when you need inputs in your subVI you have to create controls!
(5,078 Views)
Indicators are outputs, controls are inputs.  So if you are passing something into a function that you want immediately displayed, create a control that you can write to and then wire the control to the indicator on the block diagram.
(5,056 Views)
Waaaahh.
Thanks, I know that's what the help files said it's just counter intuitive.
(5,047 Views)
OK, so I now have a subVI full of controls which display the output from an instrument.  One of the controls displays the maximum force exterted during the test.  How do I get rid of the adjustment arrows and make it so that the user can't change the value?
EDIT:  Never mind, sorted it.
(5,039 Views)
Controls like that I tend to just hide off of the visible panel.  The user can't change what they can't see.
(5,029 Views)
And when the user should see those settings without being able to change them:
Hide the "arrows" and set the control to disabled!
(5,023 Views)
