sub-vi open and close
Hi
I am running a vi and called sub-vi,it can open and do something,but when i quit the sub-vi the was a fault ,how to do with this?
Is the code is wrong?
Please someone help
(2,958 Views)
Attach the actual VI's, in English.  It looks like there is more to your subVI then your partial screenshot is showing.  The error 1039 says you aborted your VI.  Is that that what you did?
(2,949 Views)
The sub-vi is to sending the parameter to PLC via OPC ,after changed i click the quit button the sub-vi close the front panel,but in the main vi is the code right?
Or what shold i change?
(2,946 Views)
Here is the VI
(2,945 Views)
Accepted by topic author 314159ym
No.  You should not hit the "quit" button in the subVI.  That shouldn't even be showing in a real application.  A long time ago in the forums, some one said "using the abort button to stop a VI is like stopping your car by hitting a tree, it will stop, but there will be consequences".
Why do you have an infinite while loop in that subVI?  I don't know what your boolean buttons are supposed to do since you didn't translate your VI to English.  You should design the subVI so that when the correct action is taken, it stop the loop and allow the subVI to end naturally.
(2,943 Views)
oK,I found the problem,the sub-vi did not fully closed. NOw it works
Thanks for the replys
(2,931 Views)
