string to diagram
Hello
I want  display a string in a diagram ( The string contains hexadecimals values). I hope you can help me.
Bye TomyZak
(2,935 Views)
Just put a string constant (on your string palette) on the diagram, right click on it and select Hex Display.
Check out the resources available for learning LabVIEW basics at http://zone.ni.com/devzone/cda/tut/p/id/5199.
(2,931 Views)
Hello Dennis Knutson,
I want display the String-Values in a Graph(Diagram).
(2,919 Views)
(if I understand the situation)
If the string contains hexidecimal data you can convert the string to an array of bytes and then plot the bytes on a graph.
(2,912 Views)
 Thank you, I will immediately try.
(2,909 Views)
Paul gave you the correct answer. You need to understand LabVIEW terms. A diagram in LabVIEW is the window where your source code is. A graph is an indicator on the front panel. The front panel is where the user interface is created.
(2,896 Views)
