string to byte array bug
I really have no idea why the string control is considering the input as 2 characters. I am pressing Alt and typing 0153. Not sure if the issue is related to keyboard, because I am typing on a laptop.
@altenbach - I am making a commercial application and cannot ask the user to type the hex value of the character.
Message 11 of 15
(1,605 Views)
It might be yopur keyboard. When I tried to look at your issue whenever I type Alt+153 (numpad) I ended up with the character Alt+214. THis happened even in Notepad so it is not a LabVIEW issue. As stated above, character encoding can be very tricky to get right.
Update: Alt+0153 works in Notepad and LabVIEW for me.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 15
(1,589 Views)
And having to ask the user to input alt+4 numbers is simpler how? How many different special characters do you need? Maybe you can make a small LabVIEW keypad containing all the special characters you need?
Message 13 of 15
(1,575 Views)
I know typing Alt+4 letters isn't easy in any sense, but its a standard. I do not have any specific list of the special characters. I just want to support the complete ASCII range of values.
Thefunny thing is even though the string control is displaying the trademark symbol correctly, it is interpreting it as 2 characters.
Message 14 of 15
(1,572 Views)
As I mentioned before, the issue is with the encoding that LV is using, it can change on the fly.  My guess is that you used copy/paste from a program like Character Map or Word or Notepad to enter a value.  The LV document on Unicode issues the following warning:
Note: The state of the InterpretAsUnicode property of a string element may be changed dynamically if text is pasted or entered into the text element by the user. The display mode (InterpretAsUnicode) of the text element will automatically adapt to Unicode or ASCII depending on the type of text entered into the control.
•    If you paste a Unicode string into a text element the InterpretAsUnicode property is turned on.
•    If you paste a regular ASCII string into a text element the InterpretAsUnicode property is turned off.
Very easy to demonstrate this:
Create a byte array with the values 0x22 and 0x21 (34,33).  Use Byte Array to String to display it.
Run the VI:  You see "!
Empty the string indicator
Open Character Map : Run charmap or find it in System Tools.  Choose Arial Unicode MS for the font, select some Kanji character.  Copy and paste into the string indicator.
Run the VI:  You see the trademark
Empty the indicator, type 'abc' into it.
Unless you take charge of the encoding, it is possible for LV to do some strange things to you.
Message 15 of 15
(1,562 Views)
