string to binary array
Hello
I am trying to convert a string of characters into binary. The first part works (binary byte array), but I am having some trouble separating the byte array into single bit that I can change the value (only 0 or 1). Does anybody have an idea how to do this? It will be awesome if someone has an idea.
Each character is represented by its corresponding binary (second part).
Thank you so much!
Smiley Wink
Message 1 of 12
(8,819 Views)
could you post the vi, I don't see what you want to do...
regards,
V-F
Message 2 of 12
(8,791 Views)
Accepted by winniewanda
Hi winnie,
try this:
Message 3 of 12
(8,787 Views)
Christian
[EDIT] Ups, I should refresh my browser from time to time. Gerd was faster!
Message 4 of 12
(8,780 Views)
Thank you so much. You guys are awesome
Smiley Wink
Message 5 of 12
(8,744 Views)
Can you please attach this VI here?
Message 6 of 12
(5,263 Views)
Hi Namra,
11 years ago I attached a snippet, so what are you looking for?
Message 7 of 12
(5,255 Views)
Kindly show me how to convert a byte stream into a bit stream in labview.
Message 8 of 12
(5,253 Views)
The code is already there. The link Gerd showed in his post explains what a snippet is and how you can use it. And it’s pretty much anyhow just the To Boolean Array function, you can search for that in your palettes.
Rolf Kalbermatter  My Blog
Message 9 of 12
(5,231 Views)
Hi Namra,
It is shown in those 11 year old messages!
One addition:
In those 11 years LabVIEW learned some new tricks.
Now you can create a 1D array at the loop output tunnel, instead of that 2D array created in the snippet…
Message 10 of 12
(5,214 Views)
