string to ID array
How to simply convert string in to 1D array?
Message 1 of 9
(5,220 Views)
There are many ways.  And it all completely depends on the format of yoru data.  Do you have any examples of data that you have and then what your array should look like?
Message 2 of 9
(5,217 Views)
Please see below attached image:
Message 3 of 9
(5,200 Views)
Joseph,
Please explain how your image would help the original poster.  It doesn't make any sense to me.
Message 4 of 9
(5,192 Views)
We really need an example of the string you have and how you want it to look after.  Put a string on the FP with the text you get next to an array (also on the FP) of what you want the end result to be.  More than one example would be even better.
Message 5 of 9
(5,187 Views)
I have two thing which i need to do separately:
1) I need to convert the output of "Sound input read.vi" in to string.
2) I need to convert the string in to the input of  "Sound output write.vi"
Message 6 of 9
(5,173 Views)
Why do you need it to be a string?  Please explain what exactly you are trying to do.
Message 7 of 9
(5,154 Views)
I want to do UDP read and write. Both of them need string.
Message 8 of 9
(5,135 Views)
Ok, now things are making sense.  Use the Flatten To String before sending the data through the UDP.  On the UDP Read, use the Unflatten From String.  There is an input of that node to tell it the data type to convert to.
Message 9 of 9
(5,122 Views)
