string to 2d array
Hi all,
I have the attached string sent via TCP server and received from my client, I want it to be formatted in a 2 row n columns (n is the number of channel). I've attached the input string and the result I want. Any help?
Thank you
(3,893 Views)
Accepted by topic author minazza
I'd go for this:
So first replace all ';' with '\n' so Spreadsheet String To Array will work nicely. The rows\columns will be transposed. The Transpose 2D Array will fix that.
I doubt there will be a more efficient way both performance-wise, as in programming effort. All three functions are very fast (when used this way).
(3,880 Views)
Thank you!
(3,851 Views)
