string output
Good Morning,
I want messages displayed in a string output on the front panel. In my vi. there is a case structure in a case structure. Inside the first case structure (in true case) I need a message e.g Ok, however inside the second case structure (in true case also) I need a message e.g No. Until now my efforts resulted in a message that blinking between Ok and No when both cases are true. How can I overcome this problem? Please keep in mind that I want the messages in the same “display (I use a string output)” thus, what I use is local variables of the same string output.
Thank you in advance
(3,612 Views)
could you post the code that you already have so that we can have a look at it.
Dave
(3,607 Views)
Accepted by LW42
I'm not sure if this is what you're lookin for; post your code if it's not.
jm
Jim
(3,607 Views)
 Thank you all very much, jcarmody gave me exactly what I wanted.
Thanks again
(3,602 Views)
