string formating
where can i find a list of all the different formats that you can use for a string being piped out of a Array to Spreadsheet String?
(4,138 Views)
Try searching for Format Specifier Syntax in LabView Help.
Cheers
(4,132 Views)
great, i found it, thank you jmcbee!
can anyone tell me, now, if there's a way to take multiple dbl's and combine them together to look like this with formatting?:
J,1234,123,12,12.9876,123,12.9876
(4,119 Views)
Jim,
Since the doubles have different formats (some as integers, some with 4 decimal precision), it is neccessary to format the strings individually before using the "Array to Spreadsheet String" function.  I couldn't find a "pretty" way to do this, but I've attached an example showing two different ways which accomplish the same thing:
I hope that helps!
Message Edited by Devin_K on 11-28-2007 03:30 PM
(4,071 Views)
You could also just do this:
Message Edited by smercurio_fc on 11-29-2007 09:07 AM
(4,045 Views)
Very true!  I knew there was something simple I was missing.  Thanks smercurio_fc!
(4,038 Views)
