string conversion to
hi to every one my Q is : is there any function that convert the following string into number "$GPGGA,111659.148,3350.8959,N,07243.9143,E,1,03,3.4,39.4,M,-39.4,M,,0000*46" iam using Labview 8.5 there is some funtion available that convert string to number but they does not convert charcter equivalent achii number they put 0 whenever string is containing character A to Z as in above sentence .. there is some character like $GPGGA N E etc ...i also need its achii code to fullfill my requirments i dont want to lose this ,as putting 0 instead of its achii equivalent , THX in advance plz its very urgent iam waiting for any solution plzzzzzzzzz
(4,515 Views)
Hi SEMAK,
"String to Byte Array" should work for you.
Mike
(4,514 Views)
Why not parse the string sentence to extract the specific parts of the NMEA code, depending upon where your application is used the letters for N/S or E/W might be very important. Or as some Lat/ Long are expressed as + for North/ East and - for South/ West make the numeric values +/- depending upon the letter - Mike
(4,506 Views)
Accepted by SEMAK
Working with small strings I often parse them like this
Message Edited by t06afre on 02-19-2009 10:22 AM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,492 Views)
Hey SEMAK-
There have been some good suggestions here. Something that you may also be interested is LabVIEW's Type Cast Function.
Hope this helps.
-Ben
Hope this helps.
-Ben
WaterlooLabs
(4,458 Views)
This sounds like a perfect excuse for a type definition.  All of the charaters have information that may be used but contain differing types.
The type def construction is left as an exercize.
Enjoy
(4,444 Views)
ok thx all of u sir ,,,,,
i will try it and reply to u its results .....again thx
(4,427 Views)
