string control reset button (mac like)
Hi all,
Has anybody ever created a string input control that has an 'X' at the right corner to reset the values in the control. If yes, how to do? I do have plenty of filters for my data in my application and it would be sweet to have similar input reset button as with the most aple applications.
Thank u 🙂
Message 1 of 11
(5,519 Views)
Hmm, an interesting idea.  Why couldn't you create a Cluster with two elements, String (a String, naturally) and Reset (a Latching Boolean).  I haven't tried making the appropriate Custom Control, but I can envision it ... .  I'm sure someone will give it a shot ... (maybe even I).
Message 2 of 11
(5,499 Views)
Hey, it works!  It was even easier than I thought it would be -- it's just a cluster, with some appropriate sizing and arranging the elements (Auto-sizing) horizontally.  I'm attaching the control -- feel free to play with it.
Message 3 of 11
(5,490 Views)
Cool! Thank you! 🙂
Message 4 of 11
(5,464 Views)
Depending upon how ambitious you feel, this would also make an interesting XControl.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 11
(5,448 Views)
Well I have to admit that I have like no clue of xcontrols. How would that work?
Message 6 of 11
(5,423 Views)
Have a look at this tutorial for XControls:
Creating New Front Panel Objects with LabVIEW XControls - National Instruments
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2jVCAQ&l=en-US
It explains it pretty nicely. There is also a LabVIEW Example that you can use as a starting point.
Refer to the Simple Dual Mode Thermometer XControl project in the labview\examples\Controls and Indicators\XControls\Dual Mode Thermometer directory.
Corinne Doppmann
Application Engineer
Message 7 of 11
(5,407 Views)
Hi all,
Thanks for your input. At the same time you recommended to so solve this task with xcontrols, I attended the lv adavnced architecture training and xcontrols are part of it. here's the solution:
Thank you all!
Message 8 of 11
(5,344 Views)
hi again,
the xcontrol I posted some time ago works like a charm, except the key focus. This seems to be an issue with any type of xcontrol that you cannot set the focus via the application anymore. I had the idea of a workaround to use methods, but I didn't got it to work. Any suggestions how to set the key focus of a xcontrol?
Thanks all!
Message 9 of 11
(4,989 Views)
What have you tried? I would be very surprised if the application key focus property worked. My expectation would be that it would give focus to the XControl as a whole, not controls within it.
Mike...
LabVIEW Champion
Message 10 of 11
(4,977 Views)
