string constant bug
Ran into this really weird problem this morning and I couldn't believe my eyes when I thought I found out what the problem really was, and I'd like to see if someone else can replicate/refute this. I checked the boards, but either I didn't enter a good enough search criteria, or this hasn't been brought up. Working in LabVIEW 8.2. Here's the scenario:
  1. Start LabVIEW.
  2. Create a blank VI.
  3. On the block diagram create a string constant.
  4. In the string constant enter the following: " anything" (note the space at the beginning - very important.). Stay in the string constant.
  5. Now, in the string constant, press the Ctrl-Left Arrow keys to move the cursor left by word. You should be at the beginning of the word "anything".
  6. Now, press Ctrl-Left Arrow again. At this point LabVIEW apparently goes nuts, pegging the CPU usage at 100%, forcing you to terminate the process.
I've been able to replicate this each time I run LabVIEW. I'm on a Windoze machine, running XP SP2.
Message 1 of 9
(5,660 Views)
I see this too.
Except I don't see a 100% processor usage, only 50%.  This is because I have a hyperthreading CPU..... Smiley Happy
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 2 of 9
(5,647 Views)
I don't know why I really wanted to see this for myself, knowing that it would probably crash LabVIEW. Nonetheless, I did it. It acted exactly as you said. 100% CPU and when I closed the vi it said LV wasn't responding.
A very weird bug, indeed.
Message 3 of 9
(5,641 Views)
smercurio_fc,
i could reproduce it as well using LV 8.2.
Reported it in CAR ID 47C9QOPT.
Norbert B.
NI Germany
Norbert
Expert: Geometry
Message 4 of 9
(5,634 Views)
By the way, this also occurs with Controls on the front panel......
It's not specific to Constants.
Shane.
Message 5 of 9
(5,627 Views)
Thank you all for confirming this. At least this time I wasn't out of my mind. Smiley Happy
Message 6 of 9
(5,609 Views)
Somehow, the CAR ID's got mixed up, here the correct one:
47C9SPPT
Norbert
Norbert
Expert: Geometry
Message 7 of 9
(5,591 Views)
It behaves the same way on Mac OS X, except that the meta key is Alt (or option) rather than Control.
Lynn
Message 8 of 9
(5,577 Views)
This was reported to R&D (# 47C9SPPT) for further investigation.
Message 9 of 9
(5,491 Views)
