02-24-2011 06:45 AM
I have a question about the stop button in a loop. When the stop button gets activated, does labview continu the current loop cycle or does it stop exactly when the stop button is activated and you get the results of the previous loops?
02-24-2011 06:57 AM
It completes the iteration. Depending on the dataflow, it is possible that the button is read early in the iteration when it has not been pressed and one additional iteration may occur before the loop stops. This will typically only occur if the code in the loop takes more than tens or hundreds of milliseconds per iteration.
Lynn
02-24-2011 08:37 AM
hi.... im new to Labview...
i have some doubts in programming with this,,,
i started learning labview. but couldnt understand how to build application in this. im a computer science student did c c++ java visual studio n almost programming laung's.. now i got intrst in learning this G programming.. plz can anyone guide me... plz reply
02-24-2011 08:48 AM
You should start a new thread rather than hijacking someone else's thread on an unrelated topic.
Start by working through the Getting Started tutorials which are available on line.
Lynn
02-24-2011 11:54 AM
I am actually honoured he picks my topic to hijack!
02-24-2011
01:26 PM
- last edited on
09-15-2026
02:35 PM
by
Content Cleaner
harry: If you're looking for LabVIEW tutorial, start here: https://learn.ni.com/learn/article/labview-tutorial
If you're asking specifically how to build an application from your code you need to create a project and build your executable in the build specifications section. Then you can create an installer from that also from the project window. The LabVIEW Help can teach you all you need to know.
02-25-2011 10:50 AM
am really sorry for that.
