LabView 8.6 Installer Build Unsuccessful - "Error in action: [TagExists?]"
I am trying to build an installer for my application. The exe and source directory files all work great, but the installer build was unsuccessful. The details of the error are as follows:
CDK_Item_OnDblClick.vi.ProxyCaller >> CDK_Item_OnDblClick.vi >> CDK_InstallerConfiguration_Editor.vi >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_PreBuild.vi >> CDK_Validate_BuildRules.vi >> CDK_TargetTree_FileFGTransfer.vi >> CDK_FGMgr_DirInfo.vi
Does anybody know how to fix this?
Message 1 of 18
(6,443 Views)
by "Source Directory", I mean Source Distribution.....    this is what seems to be causing the problem. Without including the Source Distribution files, the installer builds fine. Are Source Distributions supported in the installer builds?
Message 2 of 18
(6,440 Views)
As long as your source distribution is also in your project, you should be just fine.  I just added a blank vi to my project, built a source directory, and then built an installer which includes the vi from the source directory just fine.
Any reason you are trying to include the source distribution in an Installer?  What version of LabView are you attempting to build this on?
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
Message 3 of 18
(6,407 Views)
I've just got a similar error message in the same situation (build an installer combining exe and source distribution with LabView 8.6+Application Builder):
CDK_Item_OnDoProperties.vi.ProxyCaller >> CDK_Item_OnDoProperties.vi >> CDK_InstallerConfiguration_Editor.vi >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_PreBuild.vi >> CDK_Validate_BuildRules.vi >> CDK_TargetTree_FileFGTransfer.vi >> CDK_FGMgr_DirInfo.vi
Actually it's working if the source distribution is a simple llb but it fails when the source distribution is a llb associated with a data folder.
Moreover, the build configuration for the installer always forget the source distribution I have included the last time I opened it; don't know if it could be related.
Does one of you manage to solve this issue?
Message 4 of 18
(6,261 Views)
Pierre,
I'll look a little more into this issue this week and let you know what I find out.  I was unable to reproduce the error before, but I'll give it another go since it doesn't seem to be an isolated incident.
Rob K
Message 5 of 18
(6,241 Views)
Actually after verification with NI, it looks to be a bug in 8.6. It happens when you want to make an installer with a source distribution that contains both a llb and a data folder. If it's only a llb or if it's a folder instead of a llb, it's working.
Pierre Cottin
INO
Message 6 of 18
(6,217 Views)
We did end up verifying this and the issue has been reported to the R&D department for a fix in a future release.  The ID for this CAR is #137929 if you need some more information on it.
Some reported workaround include building the Source Distribution as an hierarchy or to build the isntaller using 8.5 (and including the 8.6 exe you created).
Let me know if you need any help with this, and thanks for bringing it to our attention.
Rob K
Message 7 of 18
(6,177 Views)
I am experiencing the same problem which was first reported in Sepember, 2008.  It is now March, 2009. Is there a solution yet?
Message 8 of 18
(5,970 Views)
This CAR is not covered by 8.6.1. I will check with Labview 2009 (beta) if it works. In the meantime, I zip my source distributions, put them in a folder of my project, add them to the installer and use a batch file post installation to unzip each distribution at the right location.
Pierre Cottin
Message 9 of 18
(5,949 Views)
Thanks for the reply. I'm headed back to 8.5.1 where life is good.
Message 10 of 18
(5,943 Views)
