stop a music when a certain condition is false
I want to stop (pause) a movie when  certain condition is false othewise it runs smoothly.
Best Regards
Muhammad Abul Hasan
Message 1 of 12
(3,553 Views)
Hi Abul Hasan,
Can you describe what you are trying to do with your VI? Are you controlling the movie with events in LabVIEW? Please post a screenshot or your code if you have begun writing it.
Matt J
Matt J - NI Tools Network
Message 2 of 12
(3,517 Views)
Dear Matt
Thanks for your reply.
Here I attached a VI file. In that file, a movie is running smoothly. I want to pause a movie when a variable 'a' has value less than 2. In this file I do not add a variable because I dont know how to pause a movie on the basis of variable 'a' value.
Best Regards
Muhammad Abul Hasan
Message 3 of 12
(3,503 Views)
You use a case structure.  See attached...
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 12
(3,498 Views)
Thanks for your reply. Actually I have LABVIEW 9 therefore it isnot possible to open attached file. I made it using a case structure.
If I have three variables 'a', 'b' and 'c' and I want to do the following tasks than what should I do.
1- if a>b movie runs smoothly
2- if a>c movie pause
3- if c>b movie forward or some other tasks
Best Regards
Muhammad Abul Hasan
Message 5 of 12
(3,487 Views)
Here is that file saved for LV 2009.
For your multiple conditions, is there some order of priority to the conditions?  Like and If Then ElseIf  then ElseIf?  Because it seems like more than one of those conditions could be true at the same time.  In which case you just need to use embedded Case structures.
Message 6 of 12
(3,481 Views)
Actually there is no specific order. In my case I have three variables andonly three conditions. In last example there are two conditins so we used case structure. For three conditions how I make a bock diagram?
Best Regards
Muhammad Abul Hasan
Message 7 of 12
(3,459 Views)
There has to be an order.
Suppose A>B.  And also A>C.  Do you want the movie to run or do you want the movie to pause?  Because it sure can't do both.  At the same time you could also have C>B, which means you also want the movie to fast forward?  You certainly can't do all 3 things even though it is possible for all 3 conditions to be true at the same time.
So there has to be an order where if one thing is true, then you stop evaluating and go with that.
You can embed case structures so that you can evaluate other conditions inside the false case of the outer most case structure.
Message 8 of 12
(3,448 Views)
This is the order
For three variables A, B and T there are three constants cA, cB and cT.
If A<cA movie pause
else if (B>cB OR T>cT) movie size decreases
else if (A>cA AND B<cB AND T<cT) movie runs normal.
Please find enlosed a VI file. Here in this file everything is working fine except decreasing of size.
Please help me to find out what is wrong?
Best Regards
Muhammad Abul Hasan
Message 9 of 12
(3,423 Views)
Here you go based on your logic.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 10 of 12
(3,414 Views)
