stomp client
My customer hosts streaming open data through websockets using the STOMP protocol. Just wondering whether anyone has some example code for a simple STOMP client in Labview.
Thanks!
(4,023 Views)
Hello Aartjan,
As far as I know (and can find) there's no example code publically available about this on the NI website.
However, it should be feasible to implement this yourself.
A first google search for the terms "STOMP protocol LabVIEW" shows the following implementation:
http://bergmans.com/lab/WebSockets%20for%20LabVIEW/WebSockets%20for%20LabVIEW.pdf
Next to this it should be relatively easy to implement the STOMP protocol by following the STOMP Protocol Specification (http://stomp.github.io/stomp-specification-1.1.html) and using TCP connectivity from LabVIEW.
Are you familiar with these types of implementations?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,964 Views)
I came to the same conclusion. The example code provided by Bergmans got me started very quickly and I have succesfully read some websocket streams using STOMP.
(3,954 Views)
Perfect!
If you would need some help at a certain point, then just let us know.
Kind Regards,
(3,946 Views)
