stitching
Hello
i work on a stitching interferometry project. i build the topographies of all the parts of a miroir and i need to stick them together in order to display the global topography of the mirror. (the different topographies are taken along a same direction)
Each topography is a 2D array (1020*1024). how can i search the similar zone between two images? i think intercorelation may be a good idea but i don't know how realize it.
Could you help me?
Thank you
Jordan
(2,868 Views)
Are you trying to stitch 2 arrays together removing overlap?  The easiest way to find the ideal match is to look for the minimum overlap between the edges.  Lest assume only 1 degree fo freedom if you have 2 arrays of 1024x1024 called A and B look at the average differency between overlapping n columns the right most  (1024) from A and left most (0) form B increase n from a value of 1 until you find the minimum value, this corresponds to the stitch location.  Then join A and B, remove n columns from either the high end of A or the low end of B, best might be to remove from both and replace with the everace value of both removed regions.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,842 Views)
