steinhart-hart with vernier thermistor
"R" must be scaled to kOhms
"Should be" isn't "Is" -Jay
Message 11 of 15
(1,111 Views)
How i could change it? What kind of units it is by default?
I can see that lil red dot where R wire goes to compound is it the case ?
Thanks.
KIndly,
Tadinho
Message 12 of 15
(1,102 Views)
Thanks.
KIndly,
Tadinho
Seriously?  That little red dot is there to let you know the value of AI0 is being coreced to DBL (I'm assuming from SGL).  I would have absolutly no way of knowing what hardware you have attached to node two AI0 but I bet you can apply a scale to the task.
Message 13 of 15
(1,095 Views)
Ye labview is new to me.I have started thread on WSN forums to get things clear with hardware and all wiring.
Message 14 of 15
(1,090 Views)
@JÞB wrote:
Its a fairly straightforward equasion:
WARNING, the above vi snippet has a subtle bug in it.  I have fixed the bug and now reattach the correct snippet.
The formula implemented incorrectly was
T = [K0 + K1(ln R) + (K2 x ln R)^3]^(-1) – 273.15
rather than:
T = [K0 + K1(ln R) + K2x(ln R)^3]^(-1) – 273.15
Peter
Message 15 of 15
(1,048 Views)
