How to plot an ellipse with the equation in Robert H. Bishop's book
I've been trying to plot the ellipse with the equation on Page 232, Q E7.3 of Dr. Robert H. Bishop's book.
I am currently stuck as I am unable to find a solution for this. Below is the equation which is required to
be used.
r^2= A^2*B^2/(A^2*sin^2(ф)+B^2cos^2(ф))
inputs are A, B and r with 0 <= ф <= 2*pi
Anyone got a suggestion on this? Thanks a million!
Message 1 of 9
(7,636 Views)
You have to use a XY graph. and plot the ellipse as a series of points describing x, and y positions. Equal to point P in the attachment. Hint Google and Wikipedia is your friends  ;). But feel free to post any question regarding Labview code for your school assignment
Message Edited by t06afre on 03-23-2009 01:44 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 9
(7,622 Views)
Duplicate post.
Message 3 of 9
(7,603 Views)
I just built a VI to graph an ellipse with that equation and it works fine, although R is not an input.
Looks like "A" is the X-axis radius, and "B" is the Y-axis radius.
What part are you having trouble with?
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 4 of 9
(7,576 Views)
Hi Steve Bird
Up until now I am able to plot the ellipse but the direction of the ellipse is not the same as in Robert's book.
In Robert's book, the ellipse is displayed horizontally but mine is displayed vertically. Any idea how do i rotate
the ellipse?
Thank you.
Message 5 of 9
(7,568 Views)
Accepted by topic author The cat
If "A" is the X-axis radius, and "B" is the Y-axis radius, then what happens if you swap A and B?
Steve Bird
Culverson.com
LinkedIn
Message 6 of 9
(7,554 Views)
Typically, you can eliminate all trigonometry by using complex math. xy graphs directly accept complex numbers, in which case they will graph in the complex plane. That's what you want!
Here is an example I made long ago in LabVIEW 7.0 (Ellipse2.vi), maybe it can give you a few more ideas. 🙂
(see also this old thread)
Message 7 of 9
(7,539 Views)
Hi Chris M, Steve Bird, Altenbach
U guys have been a great help!
Thanks!!
Message 8 of 9
(7,502 Views)
Absolutely perfect. Thanks!
Message 9 of 9
(4,757 Views)
