statemachine ARCHITECTURE
Here is one advantage to using strings:  If you have a requirement that the next state depends on two conditions, A and B, you can concatenate strings to call the next state.  Example, condition A might be Red, Blue, Green.  Condition B might be 1, 2, 3.  If the conditions are Red and 3, you can concatenate to form a string Red3 and use it to call the next state.  Sure you can use enums, all possible combinations of conditions, and use logic to determine which enum to select from the array, but using strings is easier in this case.  However, for the most part, enums are better.  I suspect people use strings instead of enums because it is easier and faster to code at first.  I'm guilty of this in simple applications done quick and dirty.  But one typo can destroy the time savings.
- tbob
Inventor of the WORM Global
Message 11 of 40
(3,430 Views)
Excellent point tbob about the string concatenation.
I have done this and unless I find a very good reason to do so, I will not do it again!
Short war story:
Before control refernces were available (BV 2.0?) I was developing an application that really needed them along with a bunch of other things including updating the code for part of the sytem while the rest was still running. So I invented this generic architecture that implemented all of the plug-ins as "Start"-"Run"-"Exit" and left it up to the developers of the plug-in to shoe-horn the modules into that state. The preliminary tests looked good and we brought in three other developers to help code up the plug-ins.
After attempting to explain the concepts (that included the possibility of pre-empting actions and compound branching [concantenation]) I had to accept the fact that if two PHD's and a Masters in Physics could not grasp the ideas, that it was "TOO COMPLICATED!"
I eventually  threw all of that code away!
Ben
Message 12 of 40
(3,427 Views)
YIKES!  Don't try this at home, at work, or anywhere.
- tbob
Message 13 of 40
(3,409 Views)
"Ben wrote:
updating the code for part of the sytem while the rest was still running. "
That part worked fine!
THe challenge was describing a state machine where the transition posiblities were endless and required a 3-d diagram to illustrate all of the possibilities.
Regarding the "Yikes":
Stayt tuned for a future release of RT!
Ben
Message 14 of 40
(3,405 Views)
Ok, time for a little summary of our conversation up to this point on state diagrams:
2D diagram represents your state chart: Use Enums
3D diagram "" "": Use Strings
11D diagram "" "": Use String Theory Smiley Very Happy
Message Edited by Jarrod S. on 01-30-2007 01:59 PM
Jarrod S.
Message 15 of 40
(3,401 Views)
Where are the String Theory VIs?
Lynn
Message 16 of 40
(3,405 Views)
SuperSecretPrivateStringyStuff=TRUE
Ben
Message 17 of 40
(3,392 Views)
Lynn
They only exist on palettes in several other dimensions and can only be realized by looking at LabVIEW through tiny slits in a piece of paper.
Message 18 of 40
(3,388 Views)
You already have it all. "Strings" is just another word for "Wires" and I'm sure most of your diagrams have some.
Message 19 of 40
(3,369 Views)
Actually, we have experimental string-theory versions of LabVIEW running in our labs.  We implemented it so that all the bugs exist in dimensions not used by simple earthlings.  That way, future versions of LabVIEW will be bug free. Smiley Very Happy
Message 20 of 40
(3,342 Views)
