starting background task in labview
@Ben wrote:
Hi Charles,
It USED TO BE POSSIBLE to use FTP to transfer VIs to remote machines then afterwards use VI Server to open (with complete file path) and run the VI on the remote machine.
Ben
It still is, if LabVIEW is running. Correct me if I'm wrong but doesn't LabVIEW have to be running before you can connect to the port and tell the application instance to open a VI? I *think* the OP wants the host machine to kick off a known VI on the remote machine where there was no LabVIEW process running before hand.
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 11 of 14
(835 Views)
@Charles_CLA wrote:
@Ben wrote:
Hi Charles,
Ben
Last time I did it it was for RT so the rule maybe different there.
But I seem to remember a story by Jeane-Pierre Drolet talking about forgeting code at home but he did know the static IP of his home machines so he invoked VIs on the home machine to read the file to his work machine.
But i am getting old and memory is failing.
Ben
Message 12 of 14
(832 Views)
@MikeBowen wrote:
Yes, please do.
Mike
Mike, the best example for asynchronous call and forget is actually a shipping NI example. Either search "Call and Forget" in example finder or goto:
C:\Program Files (x86)\National Instruments\LabVIEW 2012\examples\viserver\AsynchronousCallByReference\AsynchronousCallAndForget.VI
Charles Chickering
Message 13 of 14
(831 Views)
We have 2010, but I found an online reference that should get me there.  Thanks
Mike
Message 14 of 14
(824 Views)
