start administrator
   I am not a Labview programmer but I am the tool owner of a system controlled by Labview.
   The program is started in administrator mode with a right click.
    The OS is windows 7.
   I would like to know if the program can be started in administrator mode directly, with a batch file.
   The system is going to be  used by operators and I would like to smooth out the operation procedure.
(2,976 Views)
I would think so. Give it a try and see. Let us know how it turns out, either way
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,971 Views)
Accepted by SPL-PTM
Dont know why you would need a batch file, just change the option on the shortcut. Right click on the shortcut->properties->compatability->check "run as administrator"
(2,967 Views)
It worked.
Thanks a lot.
PTM
(2,933 Views)
