standard deviation error
I have a data set where all values are exactly the same however labivew is not returning a standard deviation of 0 when I perform this calculation within a loop. Please see the attatched .vi . (Perhaps I am overlooking something obvious).
(3,171 Views)
Accepted by topic author eword
Computers cannot exactly represent floating point numbers. The standard deviation you are getting is such a small number, it is effectively zero. You could easily test to see if it less than some other very small number and set it to zero if you want.
(3,161 Views)
Ok I thought it may be something like that. Cheers.
(3,155 Views)
