stability of systems
this question is regarding the stability of systems.vi in the examples section of labview 8.6
i could not figure out the logic behind the use of this(see the attached image file) block. also once i remove it and make it again, it does not work.
also see the attached vi.
thanks
(2,484 Views)
All that control does is generate the axes for the plot.  The first plot is a unit circle and the next two are the coordinate axes.  There shouldn't be a problem if you remove it, as long as you also remove the corresponding terminal from the Build Array primitive.  No real need to though.
(2,464 Views)
