ss model
While solving a state space problem, I used MathScript node to enter some code. then, I added inputs and an output to the node. but I am not able to change the type of the output to "SS model". Its not working. (I am not able to select that opyion.)
(3,231 Views)
You need to install and activate the LabVIEW Control Design and Simulation Module to access the ss function. If you have this module installed, then let me know...
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,207 Views)
I have this module installed and use many other options like CD construct state space model, etc in that module.
(3,204 Views)
Accepted by topic author Raghavendra1
Then, just try to do the following script:
sys= rss(3,1,1);
and make the 'sys' as your output on the node. It should give you the state-space model.
Notice that my model is a 'state-space' model. If your model is another type, like a transfer function, then you have to convert the model to ss using:
sys = ss ( sysTF);
(3,184 Views)
many thanks, i got this.
(3,177 Views)
