sql-lv Free ODBC problem connecting to Firebird Database
Hey ramses64,
Do you have a database setup using firebird?  I am using version 1.5.6 of the firebird database.  I can only give examples relating to that version.
-Branson
Message 11 of 16
(1,837 Views)
I have a firebird database. My version is 2.1, but it would be glad if you could give me exemple (vi + database for exemple) in your version.
Thanks a lot.
V-F
Message 12 of 16
(1,831 Views)
Branson,
did you thought to my exemple ?
thanks a lot,
best regards,
Vincent
V-F
Message 13 of 16
(1,804 Views)
I'm still working on that example, along side the other work i'm doing.  But when I try to do a local database on my computer it does not connect correctly.  If I put the database on the server, then it works.  Still working on that part, but the example is written, just need to know how to make it work locally.
-Branson
Message 14 of 16
(1,792 Views)
Thank you verry much branson.
Vincent
V-F
Message 15 of 16
(1,784 Views)
I tried to use the method of a connection string directly into an Invoke Node for a ADODB._Connection just as Branson has shown and I keep getting a Unknown System Error (97).
I have formatted my connection string as shown here  https://www.connectionstrings.com/firebird/
Any suggestions?
Doug Ferguson
Message 16 of 16
(1,216 Views)
