splitting serial data from multiple sensors recieved from arduino in Labview?
Hi, I have 3 sensors measuring, humidity,temperature,lightintensity and soli moisture that I need to represent in different Numeric Indicators on the front panel. I want to represent the measurements in a PI&D that I drwa on the front panel.
I have built a simple labview program that recieves the Serial data from Labview by using VISA Serial and VISA Read Blocks.My problem is that the data comes as a stream of numbers , somtehing like this:
Time_Temperature_Himidity_Moisture_Light intensity
1s           20                   20          4                3
2s           20                   20          4                3
. etc
I just dont know how to split this String into several strings and show them in separate Numeric Indicators so that I have overview of the measurements from each of the instruments?
I tried String Split/Search Block, but didnt manage to achieve it.
Need some tips here.
Message 1 of 13
(7,067 Views)
Assuming you are using the PrintLn() command, you can just use the Spreadsheet String To Array to parse the string.  You can then use Index Array to get your individual measurements.
GCentral
Message 2 of 13
(7,053 Views)
I tried your tips but not getting there Smiley Sad
This is my code from arudino sketch that generates the serial data measurements:
Serial.println(String(hours) +" " + String(moistureValue) +
" " + String(pResistorValue) + " " + String(humidity) +
" " + String(temperature));
I have attached the blockdiagram and frontpanel.
I am not completely certain how this Spreadsheet String To Array works? I am getting only one value, the value showing elapsed time.The sensor value I am not able to see Smiley Frustrated
What is this delimiter tab and Array type. I dont know how I can change or expand the array size?
Message 3 of 13
(7,017 Views)
The delimiter is the character that separates the values in your data string. The default is tab, but in your case it appears to be a space, so you need to wire a single space character to that input so Spreadsheet String to Array knows how to break your string apart.
Message 4 of 13
(7,009 Views)
1. It looks like your delimiter (the character you use to separate your measurements) is a space.  So use the Space Constant and wire that up to the Delimiter input.
2. Since you are processing a single line, change that array type to a 1D array (shrink the array index to 1 item).
GCentral
Message 5 of 13
(7,004 Views)
I have tried as you suggested to add a space " " in the delimiter , but it hasnt changed anything.I am only getting one value after the Spreadsheet to Array function block and that is elapsed time. I dont know how to pull the others?
I need to get the front panel to something like the attached image of the frontpanel.
This is my goal.As you can see on the P%ID the indicated sensor values on the P%ID drawing are normal sensor values coming from arudino serial monitor and getting read in Labview.
Message 6 of 13
(7,001 Views)
You need to attach your actual VI in order for us to help.  But my current thought is that you are not letting the termination character stop the read and you are therefore only getting part of the message.  But that is just a complete guess without seeing the code.
GCentral
Message 7 of 13
(6,981 Views)
I have managed to get the data from Serial measurements in Arduino in the individual indicators representing each sensor.Please view the attached JPG files. I have also added the VI file now.
What is bugging me now is that measurements are not updated continuously. It seems like I" lose" the measurement data , and the indicators show zero "0" even though the measurements are not suppose to change.
The Labview is not updating the measurement data every 0,5s as specified, but has a lag.
I dont understand why Smiley Frustrated
Message 8 of 13
(6,959 Views)
How often is your Arduino sending the data?  LabVIEW can only get the data at the rate it was sent.
GCentral
Message 9 of 13
(6,937 Views)
My arduino sketch sets the data to  Serial.begin(9600);, means 9600 bps for Serial communication between arduino and labview I guess.
Message 10 of 13
(6,887 Views)
