split array
Hy everybody,
I have 2 arrays A and B. The B data represents some upside down pulses. I would like to:
- get the values of the array A when the signal from the array B is start decreasing on the side of the pulses
- divide the array B according to this values and get the average of each piece
I hope that somebody can help me....it's urgent!
Thank u in advance!
(2,445 Views)
Are A and B of equal length? If so you can wire both to a For loop and compare B(i) with previous value to determine if it's a flank, in which case you grab the value from A to divide with.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,437 Views)
