spike removal
Is there a simple vi or function that does the following? If the new value of a variable is greater or equal to a specific maximum value it substitutes the previous value instead, otherwise it passes the new value. Basically, I want to use it as a filter of incoming data to remove spikes.
(3,841 Views)
Try the "in range and coerce" function in the comparsion palette. You may also look at the Y[i]=Clip{X[i]} VI if you have LV pro or better
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,838 Views)
You can also take a look at the Median Filter function.
Randall Pursley
(3,829 Views)
I agree with Randall. Filtering is the best approach. Using the clipping approach may introduce some heavy signal distortionIf you only have LV base you may try a "running average" filter. You can also try a down sampling method
(3,820 Views)
Thank you Randall and t06afre. Yes, I had looked at the clip and coerce functions and unfortunately both substitute the limit values as opposed to a value closer previous data samples. I think the pt by pt median filter is closer to what I am looking for. I will report back after tests.
(3,795 Views)
