sound meter
I want create a sound meter. I want that an audio input is indicated by an
analog indicator.
I use a sound configuration and sound read, but then how can i link audio
output with analog indicator?
thanks
paolo
(3,346 Views)
You could fully wave rectify the signal (abs(x)) then low pass filter
with a Butterworth at a low cut-off frequency. Take the output to an analogue
meter.
> analog indicator.
> thanks
> paolo
(3,346 Views)
Hi Paolo,
I would suggest a rectification of the signal. But low-pass filtering isn't
that good, because you would get linear distortion (you would cut off the
high frequent signals, which should also be taken into account in a power
meter.
A better way is to take the data points to power of two (x^2) to get the
function equivalent to
power(t). Then integrate over equidistant intervals (take a running average
over n power data points).
This you can wire to an analog meter.
Have fun,
Oliver Friedrich
"Paolo" schrieb im Newsbeitrag
news:Wk7e7.3183$Ft4.156076@news.infostrada.it...
> analog indicator.
link audio
> thanks
> paolo
(3,346 Views)
Yes if its power - I thought you meant just signal level!
Of course you have to square and average.
Oliver Friedrich wrote:
> Hi Paolo,
> meter.
> Have fun,
> Oliver Friedrich
> > analog indicator.
> > thanks
> > paolo
(3,346 Views)
