RE: Write to Parallel port
First you have to change the labview.ini file and add the line:
serialDevices="COM1;COM2;COM3;COM4;COM5;COM6;
COM7;COM8;COM9;LPT1;LPT2;LPT3;LPT4;"
Then you can use the LabVIEW Serial Port Write.vi using port number 10,
and it will send a string to the parallel port. But, if you have not
yet modified your "labview.ini" file, you may receive an error -37.
I haven't use this method yet, so if it works, please email me.
Paul
prgmmr@yahoo.com
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,300 Views)
I would like to know where can i found the IV
of Labview: "write to parallel port.vi".
I found it in "parallel 8-bit digital output
port" but when I try to open it appear this:
an error occured loading VI.
Labview load error code 8:could not load VI resource.
and I don´t know what can i do?
(3,300 Views)
Hallo, palma,
Du (x) meintest am 14.08.01 zum Thema RE: Write to Parallel port:
Which OS do you use? Windows NT and Windows 2000 don't like direct port
access. For these OSs you need a special file from the NI website
("hwaccess.xxx" oder "accesshw.xxx").
Greetings!
Helmut
Please excuse my gerlish!
(3,300 Views)
I would like to know where can I found the block of Labview: "write to parallel port.vi"
I found it in "parallel 8-bit digital output port but when I open it appear:
an error occurred loading VI
(3,300 Views)
