sort in numerical order
can someone show me how to sort this in numerical order?
only the first column in order, but the rest of the columns will follow the sorted values.
does that make sense?
Message 1 of 14
(4,160 Views)
Accepted by HelloKristy
Message 2 of 14
(4,148 Views)
that works!
thanks!!!!!
Message 3 of 14
(4,142 Views)
I actually am only using the evaluation for ni 2011.
do you think you or anyone in this forum can save the
Sort_2D_Array_DBL.vi in Labview 7.0?
i only have license for 7.0.
Message 4 of 14
(4,140 Views)
Cool set of VIs, thanks for sharing pcardinale.
In this special case the following simple code would also work.
Ben64
Message 5 of 14
(4,114 Views)
I believe there is an OpenG array toolkit which includes a "Sort Array" function that can sort by any column or row. OpenG is compatible with many previous releases, so it's possible it will work with 7.1. You can get the OpenG packages through the VI Package Manager utility (search NI.com or Google)
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 6 of 14
(4,107 Views)
thats okay..i can duplicate ben's simple code.
THANKS FOR EVERYONE'S HHELP!!
Message 7 of 14
(4,104 Views)
it doesnt work for me on labview 7.0.
Message 8 of 14
(4,088 Views)
Disable autoindexing in the top two tunnels.
Message 9 of 14
(4,084 Views)
Do as Darin said and also, you have to stretch the bottom of the index array function because you want to index a 2D (and connect the output of the search array function to the column index input which is the second one). Have a look at the LV help on these functions.
Ben64
Message 10 of 14
(4,080 Views)
