solenoid valve connection with DAQ 6009
Sir , I want to connect Solenoid Valve with USB-6009 .Solenoid Valve requires minimum 6V for its operation .As I am novice for Labview so Please help me how to connect it.
(2,939 Views)
That is not a LabVIEW question. It is a hardware question. You need to add a buffer between the USB-6009 and the valve coil. The details depend on the specifications of the valve. If it is a DC operated coil with a curretn requirement of less than 500 mA you may be able to use the ULN2003 and drive it from one of the digital outputs of the USB-6009. Do not connect the solenoid valve coil directly to the USB-6009. You might destroy the USB-6009.
Lynn
(2,933 Views)
